Введение
Use this guide to replace a damaged Samsonite luggage wheel.
A damaged wheel may stick, causing the suitcase to veer off course, or preventing the suitcase from moving. A replacement wheel will help you fix the problem.
Step 1 will help you ensure that a replacement is needed and prepare for the replacement.
Step 2 will help you select the correct replacement part.
Выберете то, что вам нужно
Insert the new wheel onto the luggage, making sure that the tubes on the wheel base align with the holes in the luggage.
5 участников успешно повторили данное руководство.
25 Комментариев
Where can i get replacement wheels
i have a samsonite luggage w 4 wheels can i change the wheels for 4 sets or 2 wheels each for easier rolling
Super tuto pas à pas pour changer sa roulette ! Ce n'est pas compliqué de réparer une valise et tous les fabricants ou importateurs le savent bien. Le plus dur est de trouver les bonnes pièces... Mais nous sommes là :) https://jereparemonbagage.com
