Введение
Here we will walk you through replacing one of your keys.
Выберете то, что вам нужно
Select the key you would like to remove then slide the plastic opening tool beneath it until you hear a pop.
The key is now out and ready to be removed/replaced.
Be sure to only remove one key at a time so they will be in the same place as they were.
Почти готово!
Заключение
