Введение
This guide is for replacing a key cap on a Samsun 500C Chromebook. This is for whether a key cap fell off or if you are having problems with sticky keys etc.
Выберете то, что вам нужно
You can skip this step if the key cap has already fallen off, and you are just trying to put it back on.
Remove the original key cap by prying it off with a spudger.
Once the cap is off you press the key back onto the keyboard till it clicks.
Some keys are special and contain metal bars. These keys include the ctrl,alt, space, shift, tab, enter, search, and delete. To put these keys back on the metal bars must be slid under the metal locks, and pressed on.
2 участников успешно повторили данное руководство.
5 Комментариев
What about a key that has a lin but curved at the bottom of it and it won’t click?
My key clicked but won´t stay on.
i need a bad bleep uhhhhhhhh addison rae lil shorty the baddest yeahhhhh and she got her ways !?!?!?!?
Who the f**k said that?
me b**ch hahahah
If you pry the cap off from the bottom it can break the plastic hook. If you pry it from the top instead, it's only a clip. Once the clip is free you can gently remove the bottom of the clasp.
Sarah Walter - Ответить
