Запчасти
No parts specified.
  1. Remove the back panel of the device by taking out the seven screws on the back panel of the device. Four of the screws are under the rubber feet so they will need to be removed.  To remove the feet, pry them off with the spudger.
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. Note: The Speaker is held in with an adhesive back so some force will be needed to remove it. Remove the speaker using a spudger and detach the cord connected to it from the laptop.  The speaker location is seen highlighted in picture 1.
    • Note: The Speaker is held in with an adhesive back so some force will be needed to remove it.
    • Remove the speaker using a spudger and detach the cord connected to it from the laptop. The speaker location is seen highlighted in picture 1.
    • Attach the cord of your replacement speaker and reassemble the device.
Заключение
Garrett Kissinger
Участник с: 24.02.2014
692 Репутация
Автор 5 руководств
Команда
Michigan Tech, Team 1-2, Lauer Spring 2014 Member of Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 3
За всё время: 807
