Введение
This guide may be used to remove the battery from the Samsung ATIV Book 9 Lite for replacement. Have a Phillips screw driver ready. Be sure to keep track of all screws removed and where they belong. Dispose of the broken battery properly.
Выберете то, что вам нужно
Turn the laptop upside down to show the screws holding the back cover on.
Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
Using your hands, disconnect the battery's main cord from the main motherboard.
3 участников успешно повторили данное руководство.
2 Комментариев
please where can i get the battery 🔋
Please where can i get the battery for Samsung 930x5j910s5j940x5j
