Введение
This guide may be used to remove the charging ports from the Samsung ATIV Book 9 Lite for replacement. Have a Phillips screw driver ready. Be sure to keep track of all screws removed and where they belong. When removing the port, be sure not to damage any cords connecting the charging port to the laptop. Dispose of the broken charging port properly.
Выберете то, что вам нужно
Turn the laptop upside down to show the screws holding the back cover on.
Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
Using a Phillips #0, remove the one 3mm screw holding the metal holder/cover in place.
Using your hand, remove the metal holder that covers the port. This will take some jostling to remove.
Using your hands, remove the cord that connects the charging port to the motherboard.
Using your hands, remove the cord from the computer.
2 участников успешно повторили данное руководство.
Один комментарий
Thanks for the clear guidance on how to locate the charge port. In order to complete the job of replacing the port if it is defective I have two questions. (1) How exactly do you remove the part that inside the notebook that is directly connected to the hole where the adaptor pin is put when charging? (2) Where can a replacement part be found for this piece?
