Введение
Is the bottom case of your Samsung ATIV Book 9 NP900X3K-S01US damaged? This guide is here to help you remove and replace it.
Выберете то, что вам нужно
Close the device and rest it on a flat surface.
Flip the device over to access the ten 4.3 mm screws located on the bottom case.
Remove all ten screws using the Phillips #00 screwdriver.
Почти готово!
Заключение
