Введение
This guide is here to help replace and repair your fan assembly unit.
Выберете то, что вам нужно
Using the Phillips #00 screwdriver, remove the 10 screws holding the back panel together.
Remove the back panel.
Using the Phillips #00 screwdriver, remove the 4 total screws (2 per each fan).
Disconnect the cable connections linking each fan to the motherboard with a spudger.
Remove each fan.
To reassemble your device, follow these instructions in reverse order or follow steps 4 to reassemble your laptop.
Еще один человек закончил это руководство.
