Введение
Are the plastic keys on your keyboard broken and need replacement? This guide is here to assist you in replacing the key covers for your Samsung ATIV Book 9. A plastic opening tool is necessary for replacement.
Выберете то, что вам нужно
Lay laptop flat and open it so that the keyboard is facing you.
Using the plastic opening tool, push the thin tip underneath the key.
Pry the key off of the keyboard by lifting the opening tool while pivoting the tool upwards.
Keep lifting until the key is removed. Repeat as needed for other keys.
