Введение
This guide shows you how to replace the camera on your phone.
Запчасти
Никакие детали не требуются.
  1. Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
    • Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
  2. Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
    • Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
    • Use a Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
    • Place the screws on a magnetic mat to prevent losing them.
    • Place the Plastic Opening tool on the outside rim of the back cover.
    • Carefully circle around the rim to open the inside back cover completely.
    • Disconnect the ribbon cables and remove the back cover.
    • Carefully disconnect the volume button, the microphone connector, and the screen connector from the motherboard.
    • Pull back the side clips and lift the motherboard slowly.
    • Use the plastic opening tool to disconnect the camera from the phone.
    • Connect the new camera into the motherboard.
Заключение
10 участников успешно повторили данное руководство.
Thao Uyen Do
Участник с: 20.01.2015
827 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 7-5, Remmell Winter 2015 Member of USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 членов
Автор 4 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 5
За всё время: 968
