Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
Please locate your disc drive
Your disc drive should look like the one pictured. If your disc drive does not look as follows please confirm that you are looking at the right guide.
Once you have located your disc drive it is time to remove the drive
You will see four silver 1.1mm Phillips #2 screws located on each corner of the disc drive.
Once you have removed the four screws using a Phillips #2 screwdriver you are now able to take out the disc drive
Carefully remove the disc drive being sure not to disrupt anything else in the Blu-Ray player.
This is how your disc drive should look if you have removed it from the player correctly.
