Введение
If you ever have a need access any of the components inside the device, the first thing you have to do is remove the top cover. If you follow these easy steps, you should have no problem.
Выберете то, что вам нужно
Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
Tilt the back of the top cover forward to remove from chassis.
Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
