Введение
This guide will open the device and remove the disc tray. From within the disc tray the disc reader will be removed.
Выберете то, что вам нужно
Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
To remove each ribbon cable, firmly grip the hard plastic tab attached to the base and pull upwards.
Locate the two black tabs on each side of the disc tray. The second tab is located in the same location on opposite side of marked tab.
While pinching both tabs, slightly push the disc tray towards the front of the device, and lift the disc tray out.
Remove spring on the side of the disc tray by carefully pulling it off its hook.
Locate the two black tabs, found at the end of the black bar across the disc tray. The tabs are located on the opposite side of the spring.
While simultaneously pushing both tabs in, lift up the black plastic bar.
Remove four (4) 10 mm screws using a phillips head #J1 screwdriver.
Remove the small metal bars by pulling it outwards.
Flip the disc tray over so the laser points downward.
Pull the disc reader out of the disc tray.
