Введение
This guide will open up the device and remove the disc tray.
Выберете то, что вам нужно
Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
To remove each ribbon cable, firmly grip the hard plastic tab attached to the base and pull upwards.
Locate the two black tabs on each side of the disc tray. The second tab is located in the same location on opposite side of marked tab.
While pinching both tabs, slightly push the disc tray towards the front of the device, and lift the disc tray out.
