Введение
Use this guide to install, remove, or replace the phone's antenna.
Запчасти
Никакие детали не требуются.
  1. Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone. Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone. Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
    • Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
  2. Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone. Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone. Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
    • Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
  3. Use the spudger to pry the two plastic caps out of the top corners of the phone casing. To get a better grip, you may use the tweezers to finish pulling the plastic caps from the phone.
    • Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
    • To get a better grip, you may use the tweezers to finish pulling the plastic caps from the phone.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Remove the six 4.0 mm screws using the Phillips 00 screwdriver.
    • Remove the six 4.0 mm screws using the Phillips 00 screwdriver.
  6. Insert the plastic opening tool in the gap between the back panel and rest of the body. Slide the tool along the edges until the two pieces come apart. The circuit board is attached to the front casing. Both casings should separate without having to sever electrical connections.
    • Insert the plastic opening tool in the gap between the back panel and rest of the body.
    • Slide the tool along the edges until the two pieces come apart.
    • The circuit board is attached to the front casing. Both casings should separate without having to sever electrical connections.
  7. Pry apart the plastic tabs along the edges of the phone. Separate the front panel from the main body of the phone using your fingers.
    • Pry apart the plastic tabs along the edges of the phone.
    • Separate the front panel from the main body of the phone using your fingers.
  8. Remove the two 4.0 mm screws, one silver and one black, from both ends of the antenna using the Phillips 00 screwdriver.
    • Remove the two 4.0 mm screws, one silver and one black, from both ends of the antenna using the Phillips 00 screwdriver.
  9. To remove the antenna, disconnect the white antenna cable that connects it to the main circuit board.
    • To remove the antenna, disconnect the white antenna cable that connects it to the main circuit board.
Заключение
Ryan Rumsey
Участник с: 30.01.2013
8 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 20-1, Maness Winter 2013 Member of Cal Poly, Team 20-1, Maness Winter 2013
CPSU-MANESS-W13S20G1
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 339
