Введение
Use this guide to install, remove or replace the phone's audio receiver.
Выберете то, что вам нужно
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
Insert the plastic opening tool in the gap between the back panel and rest of the body.
Slide the tool along the edges until the two pieces come apart.
Pry apart the plastic tabs along the edges of the phone.
Separate the front panel from the main body of the phone using your fingers.
The audio receiver is a small rectangular piece connected via wire to the circuit board.
Carefully free the audio receiver so it is only connected by a small, clear plug on the circuit board.
Use the spudger to separate the clear plug from its connector on the circuit board.
Use light force to avoid damaging any fragile components.
