Введение
Use this guide to install, remove, or replace the battery. This guide is useful for the Troubleshooting Page.
  1. Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone. Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone. Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
    • Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
  2. Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone. Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone. Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
    • Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
Заключение
Ryan Rumsey
Участник с: 30.01.2013
8 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 20-1, Maness Winter 2013 Member of Cal Poly, Team 20-1, Maness Winter 2013
CPSU-MANESS-W13S20G1
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 220
