Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If your Samsung Captivate is not connecting to the network, one problem could be a faulty antenna cable. Replacing this part is very simple and can be accomplished by anyone.
Запчасти
Детали не указаны.
  1. Remove the back cover by pressing on  the bottom section of the phone and sliding the bottom piece downward.
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Place your finger on the bottom of the battery and lift to remove.
    • Place your finger on the bottom of the battery and lift to remove.
  3. Replace the old battery with the new one.
    • Replace the old battery with the new one.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Insert the spudger underneath the bottom section of the phone.
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  6. Remove the six 4.5mm #000 Phillips screws.
    • Remove the six 4.5mm #000 Phillips screws.
  7. Starting at a bottom corner, use the spudger to separate the rear case from the front display. Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step. Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  8. Separate the rear case from the phone.
    • Separate the rear case from the phone.
  9. Use a spudger tool to pry up the antenna cable from the connector on the motherboard. Pry up the other end of the cable from the connector on the antenna array.
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
Заключение
7 участников успешно повторили данное руководство.
Drew Bentz
Участник с: 22.09.2011
565 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 20-25, Maness Fall 2011 Участник Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 членов
Автор 9 руководств
Комментариев: 2
Quick question, is this the antenna for wifi or cellular network?
Michael Perdomo - Ответить
This is actually just the cable that connects the motherboard to the antenna array. I believe the antenna array that it connects to is for WiFi though.
Drew Bentz -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 3,393
