Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Place your finger on the bottom of the battery and lift to remove.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Starting at a bottom corner, use the spudger to separate the rear case from the front display.
Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
Pry up the other end of the cable from the connector on the antenna array.
7 участников успешно повторили данное руководство.
2 Комментариев
Quick question, is this the antenna for wifi or cellular network?
This is actually just the cable that connects the motherboard to the antenna array. I believe the antenna array that it connects to is for WiFi though.
