Samsung Captivate Camera Assembly Replacement
Выберете то, что вам нужно
  1. Samsung Captivate Camera Assembly Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Camera Assembly Replacement: шаг 2, изображение 1 из 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Camera Assembly Replacement: шаг 3, изображение 1 из 1
    • Replace the old battery with the new one.
  4. Samsung Captivate Camera Assembly Replacement, Rear Case: шаг 4, изображение 1 из 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Camera Assembly Replacement: шаг 5, изображение 1 из 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Camera Assembly Replacement: шаг 6, изображение 1 из 3 Samsung Captivate Camera Assembly Replacement: шаг 6, изображение 2 из 3 Samsung Captivate Camera Assembly Replacement: шаг 6, изображение 3 из 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Camera Assembly Replacement: шаг 7, изображение 1 из 1
    • Separate the rear case from the phone.
  8. Samsung Captivate Camera Assembly Replacement, Camera Assembly: шаг 8, изображение 1 из 1
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  9. Samsung Captivate Camera Assembly Replacement: шаг 9, изображение 1 из 1
    • Gently lift the camera assembly out of the plastic housing.
Заключение
3 участников успешно повторили данное руководство.
Drew Bentz
Участник с: 09/22/11
565 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 20-25, Maness Fall 2011 Участник Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 членов
Автор 9 руководств
2 Комментариев
Is this for the front facing camera
tracy mann - Ответить
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
Will Budney -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,321
