Введение
The camera assembly is susceptible to various environmental forces such as moisture, vibration, and shock. Replacing this part is easy.
Запчасти
No parts specified.
  1. Remove the back cover by pressing on  the bottom section of the phone and sliding the bottom piece downward.
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Place your finger on the bottom of the battery and lift to remove.
    • Place your finger on the bottom of the battery and lift to remove.
  3. Replace the old battery with the new one.
    • Replace the old battery with the new one.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  5. Insert the spudger underneath the bottom section of the phone.
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  6. Remove the six 4.5mm #000 Phillips screws.
    • Remove the six 4.5mm #000 Phillips screws.
  7. Starting at a bottom corner, use the spudger to separate the rear case from the front display. Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step. Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  8. Separate the rear case from the phone.
    • Separate the rear case from the phone.
  9. Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  10. Gently lift the camera assembly out of the plastic housing.
    • Gently lift the camera assembly out of the plastic housing.
Заключение
3 участников успешно повторили данное руководство.
Drew Bentz
Участник с: 22.09.2011
565 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 20-25, Maness Fall 2011 Member of Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 членов
Автор 9 руководств
Комментариев: 2
Is this for the front facing camera
tracy mann - Ответить
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
Will Budney -
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 2,160
