Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The camera assembly is susceptible to various environmental forces such as moisture, vibration, and shock. Replacing this part is easy.
Выберете то, что вам нужно
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Starting at a bottom corner, use the spudger to separate the rear case from the front display.
Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
3 участников успешно повторили данное руководство.
2 Комментариев
Is this for the front facing camera
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
