Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Sometimes the earpiece can become damaged or loose and needs to be replaced. Follow this guide to fix this problem.
Выберете то, что вам нужно
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Starting at a bottom corner, use the spudger to separate the rear case from the front display.
Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
Pry up the other end of the cable from the connector on the antenna array.
Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
Using the spudger slide the tool under the three highlighted connectors to begin disconnection
Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
Use your fingers to carefully lift up the Samsung Capivate's Motherboard from the assembly.
Gently pull up on the audio jack, taking the attached ribbon cable with it.
The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
2 участников успешно повторили данное руководство.
