Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The speaker is easily damaged by playing music too loud. This part is easily replaced.
Выберете то, что вам нужно
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Starting at a bottom corner, use the spudger to separate the rear case from the front display.
Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
Use the Phillips 00 screwdriver to remove the single screw holding the speaker assembly to the LCD.
Pull out the ribbon cable.
Use a spudger or plastic opening tool to lift up the speaker, and use your hands to remove it.
11 участников успешно повторили данное руководство.
