Введение
You may need to perform this replacement if you are experiencing noticeably reduced battery life from your current unit, or your current battery will not recharge. Ensure your device is powered off before beginning this replacement.
Выберете то, что вам нужно
Make sure your Chromebook is turned off before you begin.
Set the labtop face down on a flat surface.
Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
Disconnect the wire that connects the battery to the motherboard by pulling upward.
3 человек успешно провели ремонт по этому руководству.
