Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
You may need to perform this replacement if you are experiencing an unresponsive trackpad on your Chromebook . Ensure your device is powered off before beginning this replacement.
Выберете то, что вам нужно
Make sure your Chromebook is turned off before you begin.
Set the labtop face down on a flat surface.
Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
Disconnect the wire that connects the battery to the motherboard by pulling upward.
Using the Phillips #00 screwdriver, remove the three 2 mm screws keeping the trackpad in place.
Remove the connector between the trackpad and the motherboard by pulling upwards on it at the port.
Peel back the adhesive strip holding the trackpad in place with the heavy-duty spudger.
With the laptop slightly open, push the trackpad upwards at the rear, and pull it out from the bottom.
7 участников успешно повторили данное руководство.
2 Комментариев
Olá, gostei do site , pois apresenta um conteúdo bem rico em conhecimento gostaria de uma assistência sempre uso os métodos de reparo do site sempre da certo , porém não visualizei os manuais de reparo toubleshoting , ficaria muito agradecido caso vocês envie esses arquivos pra mim aprofundar meus conhecimentos da área de eletrônica .
atenciosamente.
