Введение
Following this guide will help you remove and replace the motherboard on a Samsung Chromebook 2 XE503c12.
Выберете то, что вам нужно
Flip device over so that the underside is facing up.
Remove nine, 7mm PH#0 screws from the bottom.
Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
Lift the panel out of the way to reveal the battery.
Using a plastic opening tool, pry the connector up from the contact.
Remove the battery from the device.
Locate the motherboard at top right of chromebook.
Remove four 9mm Phillips #0 screws and two 7mm Phillips #0 screws.
2 участников успешно повторили данное руководство.
