Введение
Issues with a broken or cracked screen can be resolved by following this guide. The only tools required will be a plastic prying device, and a standard Phillips #0 Screwdriver
Выберете то, что вам нужно
Flip device over so that the underside is facing up.
Remove nine, 7mm PH#0 screws from the bottom.
Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
Lift the panel out of the way to reveal the battery.
Using a plastic opening tool, pry the connector up from the contact.
Remove the battery from the device.
Unplug two auxiliary wires leading to the top lid.
Using the plastic prying tool, lift the hinge on the connector up and pull the connector away.
Еще один человек закончил это руководство.
