Введение
This guide will show you how to remove the bottom case of the Samsung Chromebook 3. This will allow you to get into your device for other repairs or replacements.
Выберете то, что вам нужно
Place the Chromebook face down so that the bottom case is exposed.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
2 участников успешно повторили данное руководство.
