Введение
This guide will show you how to replace the motherboard on your Samsung Chromebook 3. The motherboard also contains the charging port, HDMI port, and left side USB port. All of these ports are soldered to the board, requiring a full motherboard replacement to fix.
Выберете то, что вам нужно
Place the Chromebook face down so that the bottom case is exposed.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
Before you can get to the motherboard, remove the three 4.6mm screws from the port cover using a Phillips #00 screwdriver.
Use a spudger to disconnect the cables going to the speaker by prying outward to the right.
Use a spudger to lift the hinge locking the gold colored display cable in place.
Then gently coax the display cable from its connector using your fingers or a spudger.
Use your Phillips #00 screwdriver to remove four 4.6mm screws from the motherboard.
4 участников успешно повторили данное руководство.
Один комментарий
Thanks for the great guide! I used it to remove the write protection screw on the back of the motherboard.
My Chromebook is model number XE501C13. The only difference I noticed is that there is one less screw on the outer plastic cover. Everything else is exactly the same!
