Введение
This guide illustrates how to remove the Samsung Chromebook 3 XE500C13-K02US battery. You will need to open the device’s back panel as the battery is located inside the case.
  1. Place the laptop back cover facing up to expose the screws. Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Use an iFixit opening tool to wedge in between the case and body of the laptop. Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  4. Remove the cover exposing the inside of the laptop. Remove the cover exposing the inside of the laptop.
    • Remove the cover exposing the inside of the laptop.
  5. Remove the four 4.6mm screws with the Phillips #00 screwdriver. Remove the four 4.6mm screws with the Phillips #00 screwdriver.
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  6. Use the spudger to pry underneath the cable and gently lift the connector up. Use the spudger to pry underneath the cable and gently lift the connector up. Use the spudger to pry underneath the cable and gently lift the connector up.
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  7. Lift the battery up and out of the case.
    • Lift the battery up and out of the case.
Заключение
Mick McCarty
Участник с: 18.03.2019
739 Репутация
Автор 6 руководств
Команда
University of Memphis, Team S1-G24, Kim Spring 2019 Member of University of Memphis, Team S1-G24, Kim Spring 2019
UM-KIM-S19S1G24
3 членов
Автор 6 руководств
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 28
За всё время: 114
