Введение
This guide illustrates the process of removing the Samsung Chromebook 3 XE500C13-K02US speakers.
Выберете то, что вам нужно
Place the laptop back cover facing up to expose the screws.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
Use an iFixit opening tool to wedge in between the case and body of the laptop.
Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
Use the spudger to pry the speaker connector sideways out out of the motherboard.
Repeat this step for the left speaker.
