Введение
This guide is a step-by-step guide on how to replace the Samsung Chromebook 3 XE500C13-K02US Touchpad. You will need to remove the battery, remove the I/O board, remove the speakers, remove two port covers, then disconnect the display from the keyboard and remove the touchpad.
Выберете то, что вам нужно
Place the laptop back cover facing up to expose all nine 4.6 mm screws.
Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
Wedge a plastic opening tool underneath the cover of the laptop.
Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
Remove the cover of the laptop to expose the inside components.
Use the spudger to pry underneath the cable and remove the connector.
Remove the battery from the case.
Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver bracket.
Remove the silver bracket.
Remove the remaining 4.6 mm screw from the I/O board.
Remove the wire connector from the I/O board.
Remove the black and white wires from the I/O board.
Lift the clip of the ribbon cable connector.
Remove the ribbon cable from the I/O board.
Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver port.
Remove the red and black speaker wires from the connector on the motherboard.
Use the #00 Phillips screwdriver to remove the 4.9 mm screw.
Repeat the first two steps for the other speaker.
Remove the smaller cable ribbon from the port on the motherboard.
Lift the clip on the connector on the motherboard and remove the larger cable ribbon.
Use the #00 Phillips screwdriver to remove the two 4.6 mm screws from both display hinges.
Lift the display hinges and remove the keyboard from the screen of the laptop.
Use the #00 Phillips screwdriver to remove the three 2.3 mm screws from the trackpad.
Remove the grey adhesive tape and lift out the trackpad to remove it from the keyboard.
