Введение
This guide will illustrate how to replace your Display Screen on the Samsung Chromebook 3 XE500C13-K05US . You will start by removing the bottom case and the battery.
Выберете то, что вам нужно
Place the laptop back cover facing up to show the screws.
Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
Use a nylon spudger or plastic opening tool to pop open the cover of the laptop.
Use a spudger to pry underneath the battery cable connector, and gently lift the connector up.
Use a spudger to lift the hinge that locks the gold colored display cable in place.
Pop the cable out and remove the hinge from the motherboard.
Using the ifixit spudger, raise the adhesive holding the wireless card antenna wires.
Raise the black and white antenna wires with the ifixit spudger.
Slowly raise the panel up and fold it over to uncover the display cable on the backside of the display.
Using the ifixit spudger, raise the hinge that is locking the gold colored display cable in place.
Pull the cable away from far from you to slide it out the monitor.
Once the display cable has been detached, raise the screen up and out of the case.
