Выберете то, что вам нужно
Hold down the power button until the device powers off
Close the device and flip it over
Remove the four rubber sockets near the corners of the device
Then remove the four 4.6 mm Phillips #00 screws
Use the metal spudger to pop the back off. Near the hinges is typically an easier place to start.
Continue along the edges until the back is completely detached.
Locate the long grey box with the black band, which is labeled "Laptop Battery."
Remove the gray piece labeled "bracket battery BA61 - 03983A" located over the golden band connecting the battery and motherboard by unscrewing the two 4 mm Phillips #00 screws
Unplug the golden band coming from the battery to the motherboard.
Using the Philips #000 remove the four 4mm screws holding the battery in place.
Face hinges towards you
Pull out the white plug-in piece
Only remove the red and black wire from the wire guide
If the left speaker is broken, lift the black L-shaped piece called ">PC+ABS<S1-C(L) R0.0 BA96-07326A"
Only remove the white and black wire from the wire guide
If the right speaker is broken, lift the black L-shaped piece called ">PC+ABS<S1-A(R) R0.0 BA96-07326B"
