Введение
This guide will show you how to replace the battery for the Samsung Chromebook Plus.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
Detach battery cable grabbing the side and pulling the cable upward.
Insert the battery and push the plug into the socket downward.
Re-insert the screws in the holes circled red (on this image), which is where you removed them previously.
Insert the hinge-side middle screw (must be done first otherwise casing may bulge) and insert rest of panel. On the hinge side, press down on the sides (if there is bulging) until you hear it snap. Insert the two other hinge-side screws (marked with orange on image). After that, insert the other 5 screws (yellow).
To reassemble your device, skip steps 1-5.
7 участников успешно повторили данное руководство.
