Введение
A fast and simple guide on how to take off the Back Cover on your Chromebook. This procedure is a prerequisite for doing most repairs to your Chromebook.
Выберете то, что вам нужно
Lay the Chromebook down so that the bottom cover is facing upward.
Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
Place the opening tool in the divot between the spine of the Chromebook and the back cover.
Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
