Введение
This guide will help you replace your SD card reader in your Chromebook by showing you step-by-step on how to remove it.
Выберете то, что вам нужно
Lay the Chromebook down so that the bottom cover is facing upward.
Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
Place the opening tool in the divot between the spine of the Chromebook and the back cover.
Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
Remove the yellow tape on the left ribbon cable with a spudger.
Use a blunt precision tweezer to remove both ribbon cables attached to the SD card reader.
Gently lift the top portion of the SD card reader and pull it away from you to remove it.
