Введение
Replace a faulty or broken battery on a Chromebook XE550C22.
Выберете то, что вам нужно
Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
Continue prying around the sides to release more brackets.
Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
2 участников успешно повторили данное руководство.
