Введение
This guide will help you remove and upgrade your RAM to make your Samsung Chromebook XE550C22 run smoother.
Выберете то, что вам нужно
Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
Continue prying around the sides to release more brackets.
Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
Using your fingers, separate the silver clips that are holding the RAM in place on each side.
2 участников успешно повторили данное руководство.
