Введение
This guide will help you remove a bad SSD. The SSD is the main location that your Chromebook stores all important information such as the operating system.
Выберете то, что вам нужно
Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
Continue prying around the sides to release more brackets.
Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
4 участников успешно повторили данное руководство.
4 Комментариев
Hello where can I get I higher SSD to buy
The SSD on the Chromebook 3 is non-upgradable. This is a different model. Please post this guide in the model you have.
The samsung chromebook shown on this guide is Samsung Chromebook XE550C22. The samsung chromebook 3 ( XE500C13 ), is totally different model. I have edited the title and description to match the actual model.
