Введение
This guide will show you how to remove your current SIM card port/slot and replace it with a new one.
Выберете то, что вам нужно
Open up the back case on the phone from the groove in the bottom of the phone.
Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
Push the SD card further into its metal slot until you hear a click.
Release the card, and it should automatically eject itself.
Remove the SD card.
Slide the SIM card out of its casing by pushing on it and sliding it upward.
Carefully remove the back cover.
Locate the 7 small black screws located around the edge of the phone.
With a small philips head screwdriver, remove each of the screws, and place them in a secure location.
Removal of the back half of the casing.
Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
Use a prying motion to lift the casing up. This will separate the phone casing.
Repeat this motion all around the screen edge until the casing pops off.
Locate and release the volume button flex cable on the right.
Locate and release the pop connector on the motherboard located to the left of the SIM card port.
3 участников успешно повторили данное руководство.
