Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Show user how to install a new micro USB port into device.
Запчасти
Детали не указаны.
  1. Slide your fingernail along the edge of the device and pull at the plastic backing.
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Pull at the plastic backing gently to remove it after hearing the snap sound.
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Remove the battery from the device by pulling the battery edge upwards.
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Locate the memory card on the upper right-hand corner of the device.
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  6. Remove the seven screws from the back of the phone using the Phillips #000 screwdriver. Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  7. Remove the power button using tweezers if it did not fall out in the previous step. At this point, you can replace the power button with a new one from a manufacturer.
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
  8. Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
    • Do not rip the white cables out of the device.
  9. Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver. Snap the antenna assembly out of the device gently using your fingers.
    • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
    • Snap the antenna assembly out of the device gently using your fingers.
  10. Pry the flex cable from the top of the phone by carefully using a nylon spudger. Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
    • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
    • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
  11. Lift and remove the motherboard from the device.
    • Lift and remove the motherboard from the device.
    • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
    how do you take it off from the motherboard
    brian cortez - Ответить
Заключение
8 участников успешно повторили данное руководство.
Andrew Cunningham
Участник с: 03.10.2012
273 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 24-25, Regan Fall 2012 Участник Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 членов
Автор 7 руководств
Один комментарий
My phone doesn’t have a memory card. At least, not that I can see. What should I do?
Joshua Campbell - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 2,186
