Samsung Epic 4G Power Button Replacement
Выберете то, что вам нужно
  1. Samsung Epic 4G Power Button Replacement, Phone Case: шаг 1, изображение 1 из 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Power Button Replacement: шаг 2, изображение 1 из 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Power Button Replacement, Battery: шаг 3, изображение 1 из 1
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: шаг 4, изображение 1 из 1
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: шаг 5, изображение 1 из 2 Samsung Epic 4G Power Button Replacement, Removing the Back Housing: шаг 5, изображение 2 из 2
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Power Button Replacement, Removing the Power Button: шаг 6, изображение 1 из 2 Samsung Epic 4G Power Button Replacement, Removing the Power Button: шаг 6, изображение 2 из 2
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
Заключение
Еще один человек закончил это руководство.
Andrew Cunningham
Участник с: 10/03/12
273 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 24-25, Regan Fall 2012 Участник Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 2,213
