Введение
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's antenna/speaker module.
Выберете то, что вам нужно
Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
Pop the antenna plug off of its socket with a pair of metal tweezers.
Pry the antennae/speaker component out of its casing. You need to use a little force to get the piece to pop out.
2 участников успешно повторили данное руководство.
