Введение
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's antenna/speaker module.
Инструменты
Запчасти
Детали не указаны.
Use the spudger to gently pry the silver plastic back plate from the body of the phone.
Pop the antenna plug off of its socket with a pair of metal tweezers.
Pry the antennae/speaker component out of its casing. You need to use a little force to get the piece to pop out.
Еще один человек закончил это руководство.
