Введение
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's input jack module.
Выберете то, что вам нужно
Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
Еще один человек закончил это руководство.
