Введение
Use this guide to replace a cracked Top Rear Housing Cover.
Выберете то, что вам нужно
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Pry the top cover upward to remove it from the phone.
Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
Insert plastic opening tool under top cover.
Using hand slide top cover away from phone.
2 участников успешно повторили данное руководство.
