Введение
Use this guide to replace the battery in your Samsung Galaxy A3 (2017).
Opening the Samsung Galaxy A3 (2017) will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will loose its water-protection.
If your battery is swollen, take appropriate precautions. Do not heat your phone. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
You’ll need replacement adhesive to reattach the battery and back cover when reassembling the device.
Выберете то, что вам нужно
Power off your phone before beginning disassembly.
Use an iOpener to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
Use a small suction handle to create a gap at the bottom end of the Galaxy A3.
Insert an opening pick and slide the tip to the bottom left corner to cut the adhesive.
Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
Insert a new opening pick and start to cut the adhesive towards the bottom left side of the phone.
Use an opening pick to cut the adhesive on all sides of the phone. Leave one opening pick in every corner to prevent the adhesive from resealing.
Insert an opening pick on the right side of the phone after you cut the adhesive on all sides. Flip it sideways until you can get a good grip on the back cover.
Remove the five Phillips #00 screws that hold the motherboard covers in their place.
Use a pair of tweezers to lift up the motherboard cover including the loudspeaker and the NFC antenna and remove it.
Use the flat end of a spudger to disconnect the battery flex connector.
Insert the flat end of a spudger in the bottom right gap of the battery and start to pry it up just a bit.
Move the spudger to the bottom left corner of the battery and also pry it up a bit.
Only pry in the areas marked in yellow (rim).
Avoid prying in the area marked in red (center). This is the back side of the display.
Insert the spudger beneath the battery on the sides of the recess to cut the remaining adhesive until the battery is loose.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape and press it firmly into place for 5-10 seconds.
For optimal performance and to avoid software sided errors, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
13 участников успешно повторили данное руководство.
4 Комментариев
La batteria nuova,presenta la protezione, ovviamente tolta ma rimane ancora la colla
Immagino vada tolta per consentire di fare contatto con il display tack??!
Ho sostituito la batteria al mio Samsung a3, sul retro vi è resto di colla dovuta alla protezione. Immagino vada tolta per far contatto. Giusto?
Very instructive and easy to follow battery replacement guide!
CSD
Unfortunately I had no iOpener or proper spudgers at my disposal, so I found that a pretty thin and flat plastic (!) spatula and a hairdryer also worked. The spatula was about as wide as the battery and fit perfectly in the pocket near the bottom of the phone and the battery. A bit of gentle heat from the hairdryer and by using the spatula as a lever the battery popped out in no time.
