Samsung Galaxy A3 2015 Battery Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy A3 2015 Battery Replacement, Display: шаг 1, изображение 1 из 3 Samsung Galaxy A3 2015 Battery Replacement, Display: шаг 1, изображение 2 из 3 Samsung Galaxy A3 2015 Battery Replacement, Display: шаг 1, изображение 3 из 3
    • Switch off your phone.
    • If your screen is cracked you want to cover the front panel with tape to protect yourself from glass shards and get a better grip to lift it.
    • Use an iOpener to soften the glue on the edge of the display. Concentrate on the sides first and then on the bottom part.
    • With an iSclack or a suction handle you can lift the display a little bit to get in the gap with an opening pick.
    • In the beginning just insert the very tip of the opening pick and slide along the side to loosen the glue. Leave the top and bottom alone for now.
  2. Samsung Galaxy A3 2015 Battery Replacement: шаг 2, изображение 1 из 3 Samsung Galaxy A3 2015 Battery Replacement: шаг 2, изображение 2 из 3 Samsung Galaxy A3 2015 Battery Replacement: шаг 2, изображение 3 из 3
    • When the glue ist loosened enough on the side you can lift the display a little bit more to get underneath the display with an opening pick.
    • Take a second opening pick and work your way just around the bottom edge.
    • Be careful where the two touch buttons at the bottom are (see next step for orientation). Take your time and be patient.
    • Repeat the last step and this one on the other side.
  3. Samsung Galaxy A3 2015 Battery Replacement: шаг 3, изображение 1 из 3 Samsung Galaxy A3 2015 Battery Replacement: шаг 3, изображение 2 из 3 Samsung Galaxy A3 2015 Battery Replacement: шаг 3, изображение 3 из 3
    • Grab the iOpener once again to heat up the bottom and top part to further soften the glue.
    • Now you will be able to move the picks at the bottom closer to the home button and eventually open the display towards the top.
    • Don't open the display all the way. It is still connected to the motherboard. Also the gold foil behind the display might come off and remain glued to the midframe. You can re-attach it later.
    • If your display is still working take care to not rip the front panel off of the display. You also want to leave the top part alone to not risk cutting any flex cables.
  4. Samsung Galaxy A3 2015 Battery Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy A3 2015 Battery Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy A3 2015 Battery Replacement: шаг 4, изображение 3 из 3
    • In the top right corner you can find the connector of the display. Use a spudger to disconnect it.
    • Now you can remove the display.
  5. Samsung Galaxy A3 2015 Battery Replacement, Battery: шаг 5, изображение 1 из 3 Samsung Galaxy A3 2015 Battery Replacement, Battery: шаг 5, изображение 2 из 3 Samsung Galaxy A3 2015 Battery Replacement, Battery: шаг 5, изображение 3 из 3
    • Remove the ten Phillips #00 screws.
    • Lift up the two touch sensors in the lower area of the frame with a spudger. You can skip this step if you are careful while removing the mid frame from the back cover later.
  6. Samsung Galaxy A3 2015 Battery Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy A3 2015 Battery Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy A3 2015 Battery Replacement: шаг 6, изображение 3 из 3
    • Remove the SD card tray and the SIM card tray.
    • Use a Jimmy to lift up the mid frame on the left side of the phone where the battery is placed.
    • Be careful not to puncture the battery underneath.
    • Remove the mid frame with all its components from the back cover.
  7. Samsung Galaxy A3 2015 Battery Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy A3 2015 Battery Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy A3 2015 Battery Replacement: шаг 7, изображение 3 из 3
    • Unplug the battery connector with a spudger.
    • Use a spudger or an opening pick to get between the midframe and the battery to separate it from the glue.
    • The frame around the battery is very fragile and easy to break. If the adhesive behind the battery is too strong, you need to use an iOpener to soften it.
    • Remove the battery from the frame.
Заключение
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
45 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
203 299 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
11 Комментариев
Ich habe die Metallfolie abgemacht und jetzt geht das Handy gar nicht mehr an! Ist das normal oder müsste es zumindest einmal vibrieren, selbst wenn kein LCD angeschlossen ist? Habe noch sehr wichtige Daten auf dem Handy ….
Tim GUndert - Ответить
Why does it not mention that the screen is glued to the frame (not just around the edges)? I have now found the ifixit guide for replacing the screen that says “NOTE: The LCD is also glued to the frame and will most likely break when removing the display“. Seems a pretty important bit of information to leave out of this article when the screen needs to be removed in one piece, and one that’s just cost me a screen. Not happy.
Alex - Ответить
Actually, he does say it. Esta guía incluye cómo quitar la pantalla y el marco intermedio. Necesitarás adhesivo de reemplazo para volver a pegar la pantalla. —>>>> La pantalla LCD también está pegada al marco y podría romperse al abrir el teléfono. <<<<—
Laura Virginia Gómez Ramos -
Do you really have to take the screen off just to replace the back cover
m.brown350 - Ответить
There is no real back cover, rather a complete casing. Unfortunately the display is the only way in.
Tobias Isakeit -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 20
За последние 30 дней: 128
За всё время: 58,468
